Alright, I think I never had an actual post on this, although I made mention in another thread.
On my 2006 TB, non auto climate control model. Ac clutch not engaging when button pushed on.
Jumped my low pressure switch, no change. There was some pressure out the Schrader valve, for what that's worth. There is the 5v reference signal on the connector.
All fuses intact. Swapped relays and all work but no change.
So today, I decided to go back and work on it again, seeing as I have a bit of time now. I jumped the relay and voila, the clutch engages.
So, the clutch works, the pump works (no grinding noises), now I have to figure out what is causing the relay to not be triggered.
Any thoughts?
Any thoughts?
