A GM OEM "Old Anglo-Saxon" Expression?
7,750
I saw this image over on THIS Thread...
...and only Thomas @TJBaker57 knows the Real Answer, For Sure... :>)
  • Haha
Reactions: northcreek
All I see is 6.2k (with the 2 faded). Might be the resistance? I don't get it.
TJBaker57
2,902
Colorado
Funny that comes up today.
I was further cataloging the values today. I gathered a listing of passlock code vs the sensor return values and also collected the resistance applied across the signal wire and ground.
I have collected 4 passlock sensors from the scrapyards and I try to take pictures of the color spots painted on them. I have to think it is a code of sorts so they know what resistance value is inside the sensor.
To be truly useful I would have to crack the code that is on the outside of the housing so as not to require this destruction to get to the sensor...
Today I swapped a couple sensors on my benchtop setup of a PCM, BCM, ignition switch and cluster and sucessfully performed the 30 minute relearn for the BCM to accept the swapped in passlock sensor. Monitoring the serial data stream allowed to to identify a couple more PIDs as well, though I don't know which is which as they return the same value.
I don't get his "anglo-saxon expression" reference.
So, even if your switch is borked, you can still find the resistance by just reading it and then reproducing it with either a pot or regular resistor.
7,750
I didn't want to mention this over in @TJBaker57 's OP because like me, he is ALWAYS so very sincere about his Topics (and justifiably so...) and I did not want to bring up this impression there, lest it be Too Off Topic and cause Thomas to misinterpret my observations as being disrespectful. But honestly, when I saw this of portion of his image at first glance, it made me Laugh Out Loud.
But sometimes, having the verisimilitude of a "Classical Education" can be a curse.
My memory of this arcane, silly piece of sketchy information prompted a recognition of this 'Significant Symbology' so very out of place on Thomas' Auto Part. This is because it hearkens back to an Old English (Anglo-Saxon) Magistrate's Docket where the Bailiff would use a Particular Acronym, presently over-used and spoken too often everywhere you look in society.
But back then, it was just a brief Four Letter Description of a Common Morals Charge involving "Fornication ... Under Carnal Knowledge". Eventually, this expression would come to be used in different grammatical ways, depending upon the situations at hand. It only takes a little imagination to see and appreciate it if like mine, your head is filled with such nonsense.... :>)
Ah, just had to zoom in a bit more to see that the 6 was not an F :biggrin:
TJBaker57
2,902
Colorado
Actually, reading the resistance requires triggering the hall effect sensor/circuitry. Otherwise it is an open circuit. I had to connect 12 volt power to the Passlock sensor, then rotate the key to the start position and only then can you read out the resistance.
Reactions: Mooseman and mrrsm
What I meant by "read" is to actually read the value written in crayon on the sensor :biggrin:
chriswilson5585
