I bought a project Envoy I've been working with.
02 slt 4x4
After replacing tccm, selector switch, and cleaning encoder motor/disconnect actuator I got the the transfer case to lock in 4hi.
The front wheels didn't lock in so I pulled disconnect to find the guide pin broken. So I put it on the list. When I checked driver side halfaxel it had alot of play so I pulled off bottom cover and seen that it's leaking oil out
Of inner seal. My diagnosis is wore out bearings. So I bought the front differential and disconnect(used) and I'll be picking them up tomorrow. I read several different forums of differential replacement. And it says it's a real PIA.
Anyone with experience have any pointers on this process?
I'm gonna be doing this asap. Just want the first handers insight.
Also 4 low won't engage on transfer case.
02 slt 4x4
