265/75r16 buckshots
bgipson89
31
My buddy has a set of 265/75 buckshot tires that I measured and they were 30.5" by tape (slightly worn maybe 60% tread) would it be worth trying to see if they would clear since I keep seeing max size is 30.5? I'm not opposed to a uca flip or a slight grins if need be. Do I need to check width on them also? I'm still not sure how to discern if it will fit. If they're worth a try, I can get em for 150 bucks.
10,685
You only need to flip the UCAs if you are doing a suspension lift. I believe those shouldn't have any major width issues. If your measurement was accurate, you shouldn't have to grind anything for this set.
bgipson89
31
I have a 3" lift on the front (thread in suspension section) and measurement t was off 2 different tires.
Only 30.5"? That's on the small side for a 265/75/16. The "official" diameter for that size is 31.6". That's what I have on my TB and it wouldn't clear my UBJ without the wheel spacer.
bgipson89
31
It's actually common to be small. My 35 km2s measured like 32.75". That's why I was hoping maybe I could shove these in there. I can't afford spacers or new wheels at the moment t and need at least 2 tires. For 150 bucks I was hopeful. I guess I'll get one mounted and see. Am I correct in assuming that any clearance off the ball joint at all is acceptable? 0 movement there?
Yup. If it clears, it clears...minus a bit of potential tire expansion with heat but that would be minuscule honestly.
bgipson89
31
So test a front and go from there. Sounds like what I'll do. Nothing to look for in the back?
The back is pretty easy until you get in the 35 inch range
nadmak
