NEED HELP 2002 Chevy Suburban Transmission Slipping in 3rd Gear
BlueDazing
75
America
My 2002 Chevy Suburban started slipping in 3rd gear. I put in a rebuild kit which included changing out the 3/4 piston, the 3/4 clutch pack, the EPC solenoid, and the 3/2 solenoid. I put it back in and it's still slipping in 3rd gear. What could it be?
7,745
In the same "Cut Of The Cloth" ...the Vehicle losing 3rd Gear is THIS Thread provides more relevant assistance and useful information during this discussion:
BlueDazing
75
America
I'm going to swap the transmission with the 4L60E from my Chevy Trailblazer. Is there any chance the issue could be caused by not the transmission, but the computer system in the truck?
7,745
Doubtful. Ordinarily... the workings of the *innards* of all Hydro-Matic Transmissions depend upon Four Things, monitored by ...and added to the PCM's Calculus of what the required Shifts Up and Down the Power Spectrum are necessary to maintain the Balance of Torque Input to Output Demands:
(1) Transmission Fluid (Quantity AND Pressure via the Fluid Pump driven by the Drive Train).
(2) Temperature. High Temps THIN Down the Fluid and weaken its properties-lubricity.
(3) Timing...or "The WHEN" that certain Solenoids activate to Direct & Re-Direct Fluid Flow.
(4) Inner Component Quality and Condition. Worn Friction Disks and Failing Solenoids, etc.
THIS is "The ATSG Trouble Code Diagnostic Bible" that is the *Bees-Knees* of information anyone working with GM 4L60E to 4L80E Transmissions will benefit from having and referring to from the shelves of their Mechanic's Library:
  • 4L60E_80E_CODE_BOOK.pdf
Reactions: azswiss
59840Surfer
85
Montana
Failure of 3rd/Direct gear is typically a primary in this transmission for numerous reasons.
It's just not usually something simple like a solenoid or old fluid. It's along the lines of a blown seal from a non-vulcanized piston, a cracked/cocked piston or it can even be ratcheted steels .... all are a tear-down and rebuild.
Swapping with another transmission is kinda risky as they both have to be of the same calibration --- and that's not usually the way things go.
danfromutah
