You are correct. The stick on the right side is the windshield wiper control. The left stick controls the headlights, foglights, and cruise control. The key goes in the center console. Also the DIC controls are on the dash board.Sparky said:Totally unrelated but I just noticed... Does the 9-7x have a different column? Looks like you have a second stick off the column and your rear wiper switch is where the headlight switch is on the other GMT360s.
LMAO! gotcha 😀Mooseman said:Primer? What primer? I got this stuff from Fleabay, shipped from good 'ol China.
That looks badass bro, to it! If you do, use Duplicolor Vinyl & Fabric paint, you can get it from any auto parts place. I just repainted my center console flat black, it looks OEM manCerberus said:I was thinking of painting my panels summit white to match the exterior of my envoy but it would be nice to see what it would look like before I actually did it. I whipped up a quick photoshop deal to see what it may look like. I don't know I kinda like it...![]()
I see where your coming from and white leather would be sweet but on mine the trim around the window buttons is also wood grain so I think there are enough accent panels that would add a good amount of white to the interior. And hey anythings better then the wood grain...Mooseman said:It doesn't do it for me. If possibly the seats were white, it might work. There's nothing inside to tie into it.
Thanks for the tip! I'm guessing the vinyl paint will flex with the panels without cracking cause when putting those back in i'm assuming they probably won't go back in without a fight.Capote said:That looks badass bro, to it! If you do, use Duplicolor Vinyl & Fabric paint, you can get it from any auto parts place. I just repainted my center console flat black, it looks OEM man
Yup its not like paint at all, actually has flexibility. I have to redo my entire cargo area. I did everything back there in Krylon paint that had primer mixed with it. Cracked on the panels while it was in storage while I was in Germany 4 months. Everything else is Plastidipped, which would be the vents, B pillars, glove box, and drivers knee bolster. Gonna redo all those though with the Vinyl paint just so it all is color matched even though it all still looks great. Door panels and dash bezel are actually from 2 SS's so those are legit OEM black.Cerberus said:Thanks for the tip! I'm guessing the vinyl paint will flex with the panels without cracking cause when putting those back in i'm assuming they probably won't go back in without a fight.
That'd be cool, don't see that often at allMooseman said:How about white carbon fiber?
