Truck bucks then stalls when put in awd/4wd
blazer35
1
11716
Have a 2003 Trailblazer. When I switched to AWD and 4wd truck began to buck/hop and then stalls. Any ideas?
7,873
freddyboy61
That doesn't account for the stalling.
Where is your idle speed at? Should be around 600 RPM.
Realism
194
Idaho
what gear are you in when you put your selector on? If it is still doing it while you are in park, put your vehicle into neutral and then try.
If it continues go get your diff checked, cuz you might be binding
TJBaker57
2,907
Colorado
Well the Original Poster has not returned since joining and posting the question. However, I have a suspicion it may another case of someone swapping either front or rear differential and failing to match gear ratios. Not sure about the stalling thing but I have come across a handful of instances where the front/rear gear ratios were not matched. Tends to stop a truck in its tracks.
Reactions: Realism
catfish520.na
