Lift kit
samuelhalipchak
6
Saskachewan
When I put a 3” lift front and back, will I need to go for a whee alignment, and has anyone had issues with the tires not wearing evenly, and part breaking?
gpking
534
Berkeley Springs, WV
Yes, you should get an alignment.
I've had MarkMC's 2.5" lift kit for almost 90k miles with no issues.
8,141
Did you flip and swap the upper control arms?
10,691
I also have MarkMC's 2.5" lift in the front, for the last 2 years. He's not making them anymore, that's why you can't find them. And yes, you need to flip and swap your UCAs. It will help your UBJs by putting them at less of an extreme angle. The shop I took my truck to had no problem doing an alignment afterwards.
Reactions: gpking
samuelhalipchak
6
Saskachewan
That sucks he’s not making them anymore, but thank you for your help!
Supreme Suspension a copy of Marks lift
You definitely want to flip/swap the UCA. You DEFINITELY need an alignment after lifting and yes if a competent shop does it...you can get in spec.
jesussaves
