- Aug 25, 2012
- 955
So my lovely Envoy (I am really getting fed up with this thing) has a blower motor problem. On my way to work I had it on speed 3 and then noticed it was getting cool in my truck. I tried to put the fan on all 5 speeds with no fan engagement at all. I in the past lengthened the wires going to the blower motor so I figured that might be a problem again so I checked them and only found one to be a little loose where I extended it and it was the light blue one. I had fixed that and still no motor.
The weird thing I noticed is that if I put the recirculate on and then turn the switch to off the recirculate does not turn off at all. Normally if I were to have my blower on speed 1-5 and then turn on recirculate and then turn the blower to 0 or off the recirculate would turn off. Mine isn't doing that. I had turned the knob on the right for the blend doors and they work just fine, I can hear them engaging perfectly.
I had checked the HVAC fuses under the rear seat and they are perfect, no breaks or blows on them. I read on another thread here to check under hood fuse 35 for it being blown and I have not checked that yet but will when I go on break at work.
Can someone think of what wire or problem it could be with my truck? Those wires that come out of the HVAC control, are they ground switched or hot switched? I was thinking if it is still a problem tonight after I leave work that I could hook up a battery charger to the leads the right way and then feed power through those wires to see if it makes the fan kick on to try and bypass a problem with the switch in the dash.
