My tb ext 5.3l has developed a rattle coming from the driver's side cat on top of other issues that are popping up as well. It not a heat shield. I already have had to re-resecure the passenger side heat shield which is why I was poking around under the TB in the first place. Btw, the truck idles a lot for work, can I simply remove the one heat shield and be OK or will the heat be too much without the shield and little air movemeant at times under the truck?
Are the exhaust manifolds separate from the cats and y pipe?
My question is this:
What kind of options am I looking at?
What would you do?
First thought, was to find a shop that will cut the cats out and weld in a pipe. Here in mn we don't have emissions testing.
Second thought, have them replaced which I'm guessing means kind of costly.
And third, headers? But it looks like it's kind of a pain to remove/install the exhaust manifolds. And headers are out of my price range right now i believe.
I don't have a lot of money. I don't have access to a welder. This will probably have to be done by a shop for this. I have to fix other issues too so this is a little lower on my priority list. And I will be moving in a few short months, maybe weeks. Also, it can't be too loud as I use it for work making deliveries early in the morning(2am-7am). I wanted to put a different muffler on it before this to give it a little tone to the exhaust as well.
If I leave this alone will it do any damage? Or just annoy the piss out of me like it is now.
Any thoughts or advice is appreciated.
What would you do?
