whats this sensor?????
AV8ER
260
The thing is super britttle and broke when I was changing the belt so it needs replacement
NewfieEnvoy
525
Can you post a picture? Can't see anything on Tapatalk.
NewfieEnvoy
525
Pretty sure that's the camshaft position sensor.
freddyboy61
See picture attached
AV8ER
260
Thanks for the replies! After closer inspection it looks like the thing has been broken and glued before. My step mother now informs me its had two front end collisions and the fan clutch has been replaced twice. Likely it was broken before. I ended up reglueing the sensor with some adhesive and its working properly now
gmac310
Why not just buy a new one? It's super easy to replace and costs less than $30 at any parts store.
limequat
520
More than likely, what broke was the 90 deg connector. NBD if that breaks, it's just there to keep the harness out of the fan. I agree that superglue is a proper fix (epoxy would be better). Pretty sure that part is not separately serviceable, otherwise.
ljoh.sl6
