jeffro312
the roadie said:That's in-line with what I get, although my variations are slower. How many miles since the last time you cleaned the throttle body, Seafoamed it, or changed the plugs?
the roadie said:700 is what folks report who are only looking at the tach with relatively low resolution, I think. With a scan tool or Scangauge you can get 3-digits of resolution. Of course, resolution is not accuracy, but it is 3-digits. The exact RPM commanded by the PCM after warm-up, and in the presence of no other parameters (like vacuum issues) that bump it up, is either 615 or 625, using HPTuners.
CaptainXL said:No low resolution here. I use Torque and it tells me that both commanded and actual rpm is 700.
I guess the burden of proof is on those not using a scan tool to look at commanded rpm. Else there could be different programming for idle speed to correct certain conditions or to improve alternator output at idle.
Jeffro please post the pcm commanded rpm at idle. That should make things clear.
the roadie said:The O2 sensor should fluctuate from high to low faster than once per second. Unless it's old (>100K miles) and getting sluggish from carbon buildup. How many miles do you have total?
the roadie said:The post-cat O2 sensor is SUPPOSED to be stable. The cat is doing its job.
The pre-cat sensor is clogged with carbon, and is horribly sluggish. And note its variations are about the same frequency as your idle variations. The pre-cat O2 sensor is supposed to wiggle around 1 Hz.
Sparky said:Yeah that pre-cat O2 looks to be quite tired and worn out.
Have fun removing it from the manifold. I suggest soaking it with PB blaster for a couple days before attempting to wrench it out of there. Spray it when cold, then later go for a drive and get it warm. Repeat for a couple days.
I had to do an emergency O2 sensor yank and replacement a month or two after buying my truck and had to use a big pipe wrench to get it out of there. Spraying it would have helped I'm sure but I had no choice as it totally died suddenly. Thankfully the neighbor had said massive pipe wrench.
jeffro312 said:Your the best Roadie thanks man. I'll replace pre cat then. As I'm sure cleaning it won't be sufficient enough.
CaptainXL said:If you want to see if the O2 sensor is the reason for your idle variations you can unplug the sensor and see if it smooths out. Duane at Realfixesreal fast explains this in one of his O2 sensor videos.
To remove the sensor your are gonna want to clip off the wire to remove it with a socket. So cleaning it isn't an option. Don't remove it with the 02 socket or it will strip. If it gets stripped you will need a pipe wrench to take it out. in order to use a pipe wrench the heat shield needs to come off. can be a real pain if not tackled right from the start.
jeffro312 said:Thanks guys for all the info. I'm going to assume when I bought car the dealer replace exhaust manifold as old on was cracked. So only 10k miles since sensor was installed. I'll tackle this Sunday (my only day off) and see results.
You have me curious about unplugging it I thought about that but just assumed unplugged is same as bsd;/ not working. Give it a shot
I'm seeing about 5 seconds from peak to peak on his screen shot. 5, 10, 15 seconds as on the bottom edge time scale. I think that's about five times too slow. I misplaced my Bluetooth adapter, or else I'd look at Torque to confirm, but am I missing something about the time scale?CaptainXL said:...At idle it will switch about once every second as shown on a scan tool. ...
the roadie said:I'm seeing about 5 seconds from peak to peak on his screen shot. 5, 10, 15 seconds as on the bottom edge time scale. I think that's about five times too slow. I misplaced my Bluetooth adapter, or else I'd look at Torque to confirm, but am I missing something about the time scale?
jeffro312 said:not sure if this will be readable but a short blip of a few sensors while driving down the highway
yea not sure how to delete a post this is useless ill try again
is that visable
jeffro312 said:ok soo now theres this loud ticking noise... anyidea. one thing after another
jeffro312 said:can u recoomend where to get this guage and where to connect it to test? is this something a autoparts will have on its list of loaner tools???
also where would i find what the vacuum should be
jeffro312 said:so i took previous advice and recorded the misfire count during a drive... not as long of a drive as requested
but just a sample ill drive longer tomarrow
https://www.dropbox.com/s/v3mujjpxo6xk40d/trackLog-2012-Nov-30_09-23-24.pdf
CaptainXL said:Well I see a bunch of misfires. Thats quite a lot for only a minute of time. When were the spark plugs last changed?
You are going to want to get a vacuum gauge on it as well to see if these misfires are due to a vacuum leak.
Change fuel filter and check pressure as well. Run some water remover (iso heat) and fuel injector cleaner as well. Fill up with top tier gas. 87 octane.
jeffro312 said:and i usually put 93 octane in just because its a habit from previous cars i had required it so i figured im used to paying extra higher octane cant hurt right?
CaptainXL said:Unless you got a tune that requires 93 octane I wouldn't use it. 87 is all that is required. It's just a waste of money. It won't give you more power.
Higher octane will create carbon deposits and over time will cause engine wear, overheating, and poorer fuel economy.
My advice is to use 87 octane and save your money for a tune or any repairs you will need down the road.
