C-ya
- Joined
- Aug 24, 2012
- Posts
- 1,098
For anyone that knows, can you put the shank in either the up or down position when attaching the ball mount? My TB's receiver is higher than the pickup I used to pull my camper with (and the truck was too high), so I finally bought a new hitch to replace what came with the camper. I need to have the shank turned down to provide a drop to keep the camper more level. I have seen pictures and real-life examples of them mounted both ways, but the instructions that came with this one only show it facing up (rise).
Here is a "down" mount - Pro Series Weight Distribution System w Friction Sway Control - Round - 10,000 lbs GTW, 1,000 lbs TW Pro Series Weight Distribution PS49903
Here is an "up" mount - Reese SC Weight Distribution System w Sway Control - Trunnion - 10,000 lbs GTW, 800 lbs TW Reese Weight Distribution RP66153
I posted this on the other TV site, but it seems like this one has more activity.
Thanks for the advice.
...... I have refurbished / set up two trailers in the last year and a half and all my electrical "problems" seemed to come back to a ground connection. You try everything and then you find the ground issue....I think there is a "Murphy's Law" saying that covers that.
