Water in cab when it rains
Brian K
Hi all
I am having a problem with water coming into the cab, which gets the floor wet, when it rains. Both sides get wet and it appears to be coming in via the HVAC ducts.
I took the vehicle to the dealer for this problem when it was under warranty but they couldn't reproduce it using a hose.
Is this a common problem - any fixes here?
Thanks
Brian
Brian K said:
Hi all
Thanks
Brian
Need your profile completed with vehicle info. Do you have a sunroof?
I have the same problem, but it appears to be on the driver's side only. And only when it's a heavy rain and the veh has to be parked on a certain angle. Going to tear apart the dash tomorrow and see if I can find the culprit.
dieseljones007
