Recently, I managed to break one of the Stainless Steel Nose Bridge Pieces RTF OFF of my Michael Ryen Reading-Computer Glasses and after finding a "DBOM" (Dead Balls On Match) over in Europe... I'm happy to report that the New Frames finally arrived and I was able to swap my Prescription Lenses into them as a PERFECT R&R.
BUT... NOT BEFORE GETTING THIS TASAINU SCREW-DRIVER SET KIT.
This was absolutely necessary because ALL of my other Cheap, Bent Straight-Blade "Eye Glass" Screw Drivers were absolutely USELESS. It follows on that there are so many GOOD things to say about this Kit that will DAZZLE those of us who perform repairs for Cell Phones, Computers and YOU NAME IT...but want to be able to carry around the Screw-Drivers in our Pants Pockets...and NOT have them fly all over the place after lifting the Cover Lid.
THIS Unit Provides us with DIFFERENT Solutions as follows:
(1) A Dove Tail Sliding Cover over a Slender Designed Case that is Flat with Rounded Corners & Edges.
(2) Instead of the usual 'Friction Insert Hold' THIS case uses 'Mild Magnetics' to Keep the Tool Set In PLACE!
(3) The Sliding Case Cover eliminates all the *Fumbling & Bumbling* of losing the components when needed.
(4) The Nickel Steel Design and Variety of these Screw Driver Variants are Very High Quality.
(5) How can you Go Wrong spending $5.50 on such a Universally Useful Tool Set?
Available for $5.50 over on Amazon:
Naturally... I Bought TWO of these TASAINU Kits ...because I knew I needed to use either a Diamond or a Sapphire Impregnated File to Grind down one particular Straight Blade (Hard Nickel Steel) into a very small width... and I still wanted to have One Original Screw Driver Set available to place into the Roll-A-Round Tool Chest out in the Garage as well.
