I've been driving a 2004 Trailblazer LT for the past year. It's my first car and I am in no way a mechanic but I am ambitious and broke enough to attempt my own repairs. I've already done a lot to keep it going - struts & shocks, spark plugs, brake pads, outer tie rods, cleaned throttle body, had to replace the fuel filter, PS cooler and an ignition coil.
I've just followed a how-to thread here for replacing the rack and pinion after the driver side inner tie rod boot started to fill up and pour out PS fluid. All seemed well after working most of the air out of the system but the first sharp turn during the test ride didn't go so well. I heard a pop and felt it in the wheel and my alignment went off and lost power steering. I got back to my friend's place, lifted the car and moved the wheel around. My alignment seemed okay again . I did some 3 point turns and heard that pop a few times again (yes my arms are sore). The steering seems to be a bit easier when I raise the RPM even at idle. There hasn't been a drop of fluid dripping from anywhere. An after thought was I read it takes a little over 2 quarts to fill the system and I'm pretty darn sure I didn't/couldn't put that much in. I'm really not sure what happened but I have a few thoughts.
Could air be stuck in the system?
The pressure or return line may not be running through the rack properly?
The lower steering intermediate shaft is slipping? I had over torqued this but fixed it before installing the rack.
Power steering pump went bad?
The reman rack & pinion is busted?
All of the above?
I'm heading back to my friend's garage later to try to flush this system. This will hopefully rule out the pump and lines. Any advice would be greatly appreciated.
-KML
All of the above?
-KML
