Mommymobile8 said:
I know its been a while but I have been so busy and haven't had time to mess with the voy, but I finally got around to checking the codes again and there is now a p0741 code for tcc solenoid, before I go into the transmission and replace the solenoid is there anything else I should check first?my thought on it is that when the alternator went out it some how fried the solenoid, but I'm asking because the explanations were : 1. Tcc solenoid stuck 2.open or short circuit. 3.transmission range selector...thanks for any help that has been and possibly will be given
This code doesn't actually indicate slipping. When you have it in 3 or D and get to a certain speed and if the transmission is at a certain temperature it will apply the torque converter clutch (TCC) to effectively lock the engine with the torque converter. This code indicates that circuit is not activating correctly. This could be due to a leak in the circuit (bad seals) or the bad/clogged TCC solenoid. I can tell exactly when mine locks because I have the isolator valve that effectively removes PWM, but if you don't then you should be able to watch your gas mileage go up in either 3 or D when the TCC engages (or stay low when it fails to). I don't like to drop the pan when I don't have to... especially with Dex VI being around $6-8 per quart. But if you have to, you have to. You'll need five quarts.
It's really weird to have such a problem with so many solenoids, especially new ones. Is your filter still good? I could understand so many failing if the filter was bad and throwing debris into the valve body...
If it were me, I would order a new TCC solenoid (I found some that were only ~$15) and pull the pan. Check the resistance on the old one with a multimeter and check for debris that might be clogging it. If just debris, thoroughly clean and put it back. It should have a metal screen in the end of it you can check. Then you'll have an extra TCC solenoid in case it fails in the future. If the resistance is outside 20-40 Ohms, replace with the new one. Oh, and it goes without saying, but if your old one is clogged you should definitely replace the filter.
Have you unhooked the battery to perform a relearn on the PCM recently? If the alternator went bad then some weird stuff can happen electrically. It's worth a shot. I would also clear the codes and see which ones reoccur. Are there any other codes?
