DocBrown
- Joined
- Dec 8, 2011
- Posts
- 501
Over the weekend I had to change my fan clutch. In the process I cracked the transmission cooler outlet line which was already rusty and needed replacement. Rock Auto has the the lines but the part that connects to the cooler does not have the quick connect fittings. These are AC/Delco parts too. I can't find a picture detailed enough to see the fitting. I can only assume that its a compression fitting, but the limited photos don't look like you can turn that nut. The Dorman part looks the same way. I'm sure someone else has bought these recently. What's the deal with these? Thanks!
EDIT: I did try a search but couldn't find anything relevant.
