This looks like a start to a bad year. On Dec 27th while reversing to go to work I felt the reverse was a bit tight, I thought because it was down for a week the brakes were tight, I had to rev very high to reverse out. When I reached work I found that it would not reverse at all, it was if something was chocked against the wheel. When I start to to go home the had to rev the engine very high to go forward now, it would crawl and build momentum. At home, tried reverse, no go. Next day I tried to go forward, no go. I left it parked. Battery discharge and damaged acuator (another thread)
Today I started it up and found I can shift thru from park to 1st but no vehicle movement
Park = Park
Reverse = When accelerate, feels like if wheels are chocked but wants to move.
Neutral = Want to move foward but feels liked if wheel are chocked.
3, 2, 1 = Same as Neutral.
Took rear wheels off one at a time (-12 deg Cel). In Neutral it spins slowly and then kind of stop. Cannot stop it by hand.
Vehicle was bought at 100K Kilometer, like 5 years ago. Change all differential and TC/transmission fluids 1.5yrs ago at 160k kilometer.
Is this the famous sun shell problem?
Thanks.
Park = Park
Thanks.
