- Jul 30, 2013
- 11
My 03 Trailblazer has 120K on it and definitely has something going on with the trans. I did a AIRAID CAI and PCMforless tune a couple years ago with 50% torque management removed and stage II trans mod basically for towing but was also looking for performance and a little MPG improvement if possible. Just prior to tune I had both the trans and transfer case flushed, fluids and filter changed. Trans has a slight almost slip/clunk pulling away on light acceleration and sometimes on the 1-2 shift plus sometimes in reverse. Lightly letting on and off the accelerator it does the same and lock up may be acting up a little. When the trans guy did the flush, filter and fluid change he said everything looked fine but he did not remove the valve body so these failing parts everyone is speaking of is quite possible especially at 120K. Shifts are not what I would call firm at all or what I expected after reading posts from others with the PCMforless tune w/Stage II trans upgrade...I'm hoping this is a result of a failing separator plate, accumulator pistons, etc.?
I am looking at this kit 4L60E 4L65E 1996 2006 1870 P1870 Code Buster Combo Kit Corvette Servo Kit Book | eBay as recommended and am also wondering if replacing the stock "Boost Valve" with a new upgraded performance boost valve .490 or .500 (I believe stock is .470?) HIGH-PERFORMANCE PRODUCTS 700R4 4L60E 700 4L65E 4L60 AOD 200 items in CT POWERTRAIN PRODUCTS store on eBay! is recommended as well?. Has anyone done this too, what are your thoughts on this kit and upgrading the boost valve?
Sorry for a duplicate post in another section...I'll try an remove it or request it be removed as my post should have been here instead.
Thanks,
Scott
Thanks,
Scott
