FOR SALE Trailblazer LT Grille and Headlights
24v 4.2
430
Trailblazer LT Grille - 50 plus shipping
Trailblazer LT Headlights - 80 obo plus shipping
Headlights need restoration, buy the kit from autozone ($20) that includes a small sanding disk that mounts to your drill. The drill kit will let you sand off the clear and the oxidation, then polish it clear.
The clear coat on one side has some drip marks fom a mechanic (not sure from what), and both headlights have oxidation in between the clear coat and plastic (very common to the LT lights, both sets I've had were oxidized in the same way).
24v 4.2
430
Bump
The lights will sand clear if you use the kit. I used the same kit on another pair of LT headlights that I did my retrofit with. On the left was after sanding through the clear coat, and the right was after final sanding and polishing.
24v 4.2
430
Bump.
$60 for headlights
24v 4.2
430
Bump
Headlights come with 6k HIDs in the low beam (no ballast).
24v 4.2
430
Possibly, I am talking with a local member. Will get back to you after I hear back.
rick1
