traction control
brigadier92g
Have an 06 TB. When putting the TB into 4wd low, the traction light immediately flashes and then remains solid. No other issues. Any ideas. A couple of months ago, while driving down the freeway, traction control light started flashing and rear brakes started pulsating. Inflated tires to proper pressure and haven't had it happen since. Any ideas on the continuing TC light in 4wd low?
Thanks
I'm pretty sure traction control doesn't work in 4 Low. Best just to turn it off until you get out of 4 Low. You probably can't get going fast enough in 4 low to affect traction control anyway LOL
brigadier92g said:
Thanks for the info. We bought it used and did not get an owners manual. Thanks again for the help!
Pdfs are easy to find on the net. Highly recommended.
Yeah, and not only does TC not work in 4LO, Stabilitrac also doesn't work in 4LO, so if you have to use 4LO to get out of something in the snow, you'd be best off going back to 4HI for continued driving.
Mike
nickG
