I have a 2012 Traverse LT (3.6L VVT). Twice in a year I've been in this engine to replace the timing chain, but that's what the mechanic swears is wrong with it (misfires like crazy even after brand new plugs and coils). I'm just not seeing the obvious signs of damage/wear like I did the first time, but one thing is bugging me. When I put the last chain on (secondary, right side), the colored link is just off from the marked tooth of the Exhaust cam phaser. Everything else on all of the chains are lined up the way they should.
I can rotate the phaser clockwise slightly, and line up the chain. As soon as I let loose of the wrench, it slips and the phaser returns to where it was (I'm assuming some type of tensioner inside). The first time I did this job, I was able to hold the chain in place until I installed the rest of the hardware (tensioner and guide), everything lined up, so I called it good. This time around, I'm running into the same thing, so I'm second guessing...is that abnormal? Could it be contributing to my problems? I'm afraid to put this back together again just to need to pull it right back apart because I didn't fix the problem.
The first go at this, I replaced everything with the Cloyes VVT kit. So, new cam phasers, new chains, new tensioners, new gears, new gaskets. This time, I just did the AC Delco kit with chain and tensioners. And to be clear, once I hold the chain in place, and install the guides and tensioners to prevent the chain from moving, the sprocket stays put. But I know that the chain is preventing the sprocket from snapping back to where it wants to, and I can't help but wonder if that adjustment is somehow throwing off the timing once the engine is running. But I don't know enough about that to say for sure.
Anyone run into this before? Am I just overthinking this? Thanks for any help, I'm in limbo until I figure this out...
