Ticking Under The Hood
Dillyo82
80
I've noticed after getting out to grab my mail and leaving the truck running that there is a Ticking sound under the hood. Maybe 2 every second. Could it be my AC Clutch or Fan Clutch? Should I be worried?
Easy to turn off the AC or unplug the fan clutch to see. I'd guess the fan clutch software. Was it ever updated after the 2005 improvement?
Lima Tango
Did all 2005s have this update at birth? I have a ticking sound described exactly this same way but I have an '05 so presumably it's not the software update issue. Original fan clutch, so should I start planning for a later year style? The exact year escapes me at the moment but IIRC the later years were better...
The fan clutch hardware redesign and the PCM software update happened in calendar year 2005 sometime, but the month escapes me. 2005 MODEL vehicles could have been manufactured any time starting before 2005 calendar year, and vehicles could have been updated if you're not the original owner. GM's records might have a record of updates performed.
GM often slips in updates as the model year progresses, so there's no real way to tell other than visiting a dealer. Ick, I would so need a month of continuous showers after that process, my local dealers are such total slimes.
Lima Tango
Ugh, not looking forward to a dealer visit. If they do show that I have the older pcm software, will updating it overwrite my PCM4L tune?
Simon01
116
IIRC, all 2005 MY vehicles have the software update installed. The updated fan clutch went on 2005's built after May 2005. In my case, my TB was built in October 2004, so I had the updated software but the old design clutch. My fan clutch just went out this summer and after I replaced it with a Behr-made unit with the hardware updates and there is a big difference, especially with AC performance in hot weather.
jrSS
If they flash ur pcm yes it will. Try buying efans from pcm forless.
Mypetropig
226
When they install a tune do they have the capability of installing this software update or is this something that only the dealers can do with a TechII ? In my area its about $90 just to hook the truck up to the Tech II, then the clock starts for whatever they have to do.
jrSS
Hmm. Pm pcmforless. Or get on the website and get their # I have NO idea on that one.
6716
833
Is the fan clutch connector of which you speak located near the top of the fan shroud on the battery side? Only one right about there?
I've got a recent, random-ish clicking-type thing near the fan area. Last fan clutch was replaced three years / 75K ago. Truck is a 09/04 build, according to the driver's door.
If I can just figure out the right connector, and how to get it undone without breaking .....
Simon01
116
Yes, that should be it.
Nayel
