If you want to either Change your Fuel Filter and/or Test the Fuel Pressure... This link has good images to show its location and the Acces Fuel Pressure Testing Schrader Valve Port on the same Filter Unit:
How to replace Chevy TrailBlazer fuel filter from the year 2003, 2004, 2005, 2006, 2007 and 2008. Locate and replace Chevrolet TrailBlazer fuel filter.
filterlocation.com
@MAY03LT 's Famous "How to Test Fuel Pressure on the 02'-04' Trailblazers" provides some Good Visuals and Verbals for how to perform this Test:
Also... if you are having "Temperature Issues" that also involve problems with your Electro-Viscous Fan-Clutch acting up... be advised that it may be sharing a (5) Volt Reference Signal from the PCM with the Fuel Pump. GM uses a Class 2 Network that employs ONE SINGLE (0-7) VDC Network Wire for PWM (Pulse Width Modulation) signalling... and as such, problems with Individual Modules on the Vehicle Network can negatively impact OTHER unrelated Modules elsewhere within the Vehicle.
Using your Scan Tool and reading the History of any Trouble Codes (PXXX) can often reveal what is actually causing these problems. Your Sketchy Instrument Cluster Readings would prompt me to check for the
G201/SP201Grounding Screw that Fastens all of these in commonality to the outer hard metal shell of the Transmission hump on the Passenger side of the Vehicle below the Dash Panel . In this next video... Once again... MAY03LT explains WHY this One Ground can give us all so many headaches if it is
NOT properly connected to the Truck Body as a
GOOD GROUND BONDING CONNECTION:
So...
Welcome Back... to GMT Nation... Leo :>)
