suspension maintenance is it DIY
omaromar50
2
Dears
I was thnikin of making reqular (periodic) suspension maintenantce, is it DIY, how can I do it.
Appreciate all your inputs.
Wooluf1952
2,663
Milwaukee, Wisconsin
What kind of suspension maintenance are you looking to do?
There are no grease Zerk's in OEM parts.
I can't think of any PMing that can be done.
I may be missing something.
C-ya
1,098
Other than replacing items at a set interval, there isn't much you can do as "preventative" maintenance. Most suspension work is done when a part fails or wears enough to notice in other ways, like uneven tire wear.
There isn't much else you can do with OEM parts than inspect for wear.
Replacements have zerk fittings, which I generally lube up at each oil change/tire rotation.
SlushPuppy
