stuck door?
CodeWhite
17
Well today my rear driver side door would only open partially then I forced it half way and thats as far as I could get it. Doesn't look damaged in any way, hasn't been hit that I know of. Its 24 degreez out busts its been colder with no issue.
Don't know what's going on, its very stiff and won't open completely.:confused:
CodeWhite
17
But it did rain at 55° yesterday! Then snowed today with a low of 16°. Could it be iced? Would something break if I just yanked it open?
meerschm
1,079
not clear how far you can open the door. look carefully.
I had a rear door that part of the interior trim came loose and would catch on the door at about two inches or so open.
given the temps, I suspect there could be some ice, you could always go find a garage to pull it in. (or go someplace for a free safety check and estimate for new tires.)
I am not a big fan of yanking on stuck stuff. that is how things get bent.
Bub
159
most likely frozen, moisture could've gotten into your hinges, did you hear any noises??
Chadla11
