Excellent Images... And as you can see from the close-cropped focused versions of them adapted for this explanation...They ARE the Very Best
(...as in The Very Worst...) of Examples of what happens when Galvanic Corrosion sets up in between Dissimilar Metals that can occur in the presence of a Salt Brine - Wet Environment. Over time...ALL Exposed Braided Copper will generate Copper Oxide from Pure Braided Copper and become
DIELECTRIC AS THE RESULT:
The Green Colored Copper Wire ends prove that a good portion of that Green Infestation has invaded the length of the Ground Strap and this diminishes its ability to neutralize accumulated static or other incidental electrical energy. The OEM versions of these Bonding Straps should still be available at:
Shop for quality GM parts for your GMC, Chevy, Cadillac, Buick, or other GM vehicle at GM Parts Direct, your trusted auto parts source
www.gmpartsdirect.com
If Not.., Carefully remove their Contact Fasteners, Measure the Straps for Length and Eyelet Size and seek to purchase suitable replacements on Amazon.com. Clean the Affected Areas up with a Paste-Mixture of Water and Arm & Hammer Baking Soda. Then... Burnish the Contact surfaces to a Bright Shine and coat the intermediate surfaces of the New Bonding Strap Ends and Fasteners with a Dollop of Dielectric Grease to eliminate the return of this problem.
While this may not completely eliminate the *Crackling* issue...it will go a long way to reducing the RF Energy from Static Electrical discharge that ALWAYS produces Random Radio Waves as the Result
(Like the Sound created when there is a Lightning Strike nearby and your Speakers respond by the *Crackle* Sound due to this RF Interference). An Un-Bonded Car or Truck Hood with a Poor Ground can act just like the Arecibo Antennae used to in Puerto Rico and collect and amplify random RF Energy from Space.
en.wikipedia.org
en.wikipedia.org
