This might sound crazy... and without the justification for using it in OTHER Automotive Diagnostic Applications... like identifying HOT Coil Over Plugs based on their Infra Red Signature on a Running Engine with a Suspected Lean Misfire Condition... Such a Tool might seem to be very frivolous. But in situations like
this one, they are also useful for identifying COLD AIR LEAKS in HVAC Ducting, etc. In any case... I got mine last year and it has worked out great:
In THIS Particular situation...
Due to the Danger caused by the release of Carbon Monoxide (CO)
as Gasoline is Evaporating... the other phenomena is that Evaporation in and of itself is a
COOLING Process... **** ... and so it might be easier to spot a small Gas Leak against the local warmer background --Safely-- and so by using this type of IR Camera... it could make it MUCH easier to find the Evaporating Cold Spots around the location(s) and hidden sources of Fuel Leaks.
THIS Handy Klein Unit was on sale back then and from the general search on the Quality IR Cameras, they all seem to run about *Three Benjamins* in Price and if you decide to use it and it finds your Mysterious
(and very dangerous) Gas Fume Source...
then it would be Worth Every Penny!:
**** The Physics of
WHY this Cooling Effect occurs are Simple:
In order for a Liquid to convert from that *State of Matter*... into a Gas...It requires
ENERGY to excite the Molecules in the Liquid Fuel enough to separate and float away...
and so it takes up the Energy of HEAT from its most immediate surroundings in order to Drive this Phenomena...
by Scavenging that Energy and LOWERING THE SURROUNDING TEMPERATURE.
You can demonstrate this yourself by smearing a Drop of Water on your Forearm and while blowing air over that location, you will feel just how Cold it becomes as the Water enters a Phase Change and converts from a Liquid State into Water Vapor. Evaporating Liquids with such a High Volatility (VOC) Level like Gasoline
should create quite a distinctive *COLD SPOT* Signature on a decent IR Camera Screen:
DuckDuckGo. Privacy, Simplified.
duckduckgo.com
