Shana7711
- Joined
- Nov 29, 2012
- Posts
- 82
So approximately 9 hours into my 14 Hour Dr. from North Carolina to Michigan, My service engine soon light came on. Just what I wanted to see during my drive. Anyway, I stop at an auto zone on the way and have them check the codes that came up, not thinking there'd be more than a couple, … There was at least 15 different codes that came on, mostly related to the transfer case and 4WD. Unfortunately the guy that helped me not diagnose all the codes because they weren't's engine codes, instead they were vehicles specific I think.…
I have no idea what is going on. I have not used my four-wheel-drive for a few days now, and I did just get new tires. Below is a picture of the receipt that the AutoZone and I printed out for me for the codes he could diagnose, and a list of the codes that he couldn't. I had him clear all the codes and since then the light has not come back on that was almost 100 miles ago.
I do hear a slight intermittent humming noise coming from my left front tire, feels like a vibration. It's a very steady noise happening every second or so, and only happens when I'm on the highway going 60 or more. I've been told that this could be a flat spot on the tire or may be due to a balancing issue or alignment issue. The tires were just balance, and I had a mechanic drive it to see if it need an alignment, he said it did not.
To add further confusion, The left front tire is also the one I had a problem with rubbing against the inner wheel well when I first got the tires put on. The tires, wheels, wheelwells, are all the same size on both sides. But on the left front tire there is about 1 inch behind the tire and 3 inches in front of the tire, whereas on the right side there is 2 inches in front of and behind the tire
I apologize for any spelling errors or grammatical errors, I am speaking to my phone right now because I am driving
Any advice or information that anyone can give would be helpful, thank you
View attachment 25540View attachment 25540
