I had the Service 4WD light happen earlier in the year. I've replaced the TCCM with one from a 2003 Envoy and that fixed it for a while (maybe 6 months). Now it's back. The switch lights up on start as I would expect, but all lights go out. I've done the "switch exercise" and I've tried a working switch as well. Last night I pulled the #8 fuse and also tried pulling the negative. Didn't magically fix it.
The odd thing is that I can get it to engage another mode; just not while the car is running. When the car is off, if I move the switch from 2HI to 4HI it will engage 4HI when the car is started. I really only use those two modes (A4WD is useless and I have no need for 4LO where I am). I don't recall being able to do this before the TCCM replacement.
Here's the work I've done lately (in case it's relevant) that I can recall:
Can a place like Advance Auto/AutoZone read the code for the 4WD? If so, I'll wander that direction and see what it's actually telling me. I thought I read that it was something a dealer had to read.
- New Front Wheel Hubs
- New Struts
- New Tie Rods
- New Upper & Lower Bushings
- Replaced TCCM
