Seat Position Memory Issue
Jkb242
239
CLT
My 06 Denali is no longer allowing the easy seat exit position. The settings are correct but instead of moving to a rear position, it moves about an inch then stops. If the seat is manually moved it will return to the drive memory position according to the memory selection selected and appears to respond to the remote when locking or unlocking doors.
Is there a reset to the body control module that would correct this similar to the procedure when resetting the climate control system.
thanks!!
Adungyyy
