Freddy G.
- Joined
- Dec 4, 2011
- Posts
- 55
First I want to say I am sorry for posting on this topic again! I cleaned the throttle body, I cleaned my Cam Shaft Position Solenoid, and changed my spark plugs. Rough idle is mainly when I turn on the AC. When I come to a stop it idles down to 250-300rpms and feels like it wants to stall. I also noticed it does this same thing if say my windows are all the way up or down and I hold two window buttons at the same time and it also idles down/rough idle. my RPM's sit at 500. Should it be higher?
A bad motor mount won't cause your engine to 'jump', but the truck will idle rough when the transmission is in gear (drive or reverse) and smooth out in park or neutral.
