Voymom
- Joined
- Feb 3, 2012
- Posts
- 2,523
So, it happened again. My truck stalled on me again. This time it's sunny out, partially warm (Low 50's) and no moisture in the air at all. I decided I had had enough of this crap and took it down to the towns trusted mechanic to have him hook up the tech 2. I told him what was going on, new hissing sound from engine compartment(been there since the 10th) no codes, so not a vacuum leak...I'm thinking it's a pulley. Made a video and will post it below. He ran the first scanner on it, to see if there were codes because apparently OReilly's code scanner doesn't always catch everything. He did his thing, took about 10 minutes, it was a HUGE snapon laptop like very complicated looking scanner lol. He said it found absolutely no codes as to be expected. He didn't elaborate on the hissing(of course he wouldn't I wasn't paying him to fix it). He seen the drop in RPM's and felt the shaking/stuttering I have been dealing with. So, he was really curious by this point, waived the $35.00 tech 2 diagnostic fee and took it for a spin. When he pulled up he looked even more puzzled. The tech 2 showed that everything was running up to par, besides another sticky thermostat...nothing could be found. Nor was he able to reproduce the drop in RPM to get the stalling/stuttering. He then re-hooked the truck up to the big snapon scanner and asked me
Can I reset the camshaft/crankshaft something or another in case they might be low. I missed whatever the something or another actually was, which I'm hoping someone can elaborate on what it is he reset and what the reset does. He did reset whatever it was he was talking about. At this point if he told me setting the truck on fire would fix my issues, I would have walked home lol
He then proceeded to tell me that I needed to leave the truck overnight sometime so that he can try to reproduce the drop in RPM's and the stutter/stall while hooked up to the tech 2 as the issue may be intermittent, one second whatever is failing doesn't fail, and the next second it does type of ordeal. It's $35(he won't waive the fee this time) to leave it overnight. I'm wondering if it would be worth dropping the truck off to have him do this?
Now to the hissing...it's coming from the middle of the truck, so not the power steering going out, so that's why I'm guessing it's a pulley, but I don't know. I first noticed it on the 10th when I was out picking up parts for the truck(spark plugs, end links etc...). Anyways here are 2 video's. Hopefully you all can help me out with this.
Edit- Video's are taking FOREVER to bluetooth over to my pc....I will update this when they get loaded up onto youtube.
Video # 1 http://www.youtube.com/watch?v=gTo4Jrtn3jY&feature=youtu.be
Video # 2 http://www.youtube.com/watch?v=ajw9kncVh3E
