I had all the symptoms of a failed TCCM - Service 4wd light, no switch lights after start up, and wouldn't shift out of 2hi. I removed the 2 plastic panels from under the steering column AND the panel on the end of the dash. Removing the end panel is the key to making it an easy task. I bought a remanufactured Dorman TCCM from O'Reilly with a lifetime warranty for $176 with exchange of the old. I did not disconnect the battery. The new TCCM had a sticker on it with the required sequence for plugging in the 3 electrical connectors to avoid a communications error. Programming by a dealer is NOT required. On initial start-up I still had the original problem but pulling the front #8 fuse woke it up and it has been trouble free. It seems that the TCCM has a life of about 110,000 miles as this is the second replacement in 228,000 miles. I have had trouble in the past with it not shifting after several months of not turning the selector but rotating the selector switch 30 to 50 times with the vehicle off always got it working until the TCCM failed (2 separate issues). So for $176 I got a known good TCCM with a lifetime warranty and no programming needed - way to go in my opinion.
