repair TCC valve or HPtuners?
santon
119
Israel
My transmission probably has the worn out TCC valve bore. There were strong vibrations during TC lockup and release and the issue was almost solved by eliminating the PWM control and setting the TCC operation to the "on" and "off" states by HPTuners. The issue was almost solved since some light vibration is still present at TC release. Do you think that putting a repair TCC valve is better than the tuning? I was thinking about Fitzall repair valve since it could be installed without removing the valve body.
A TCC PWM elimination kit can fix the problem of the worn bore. The tune can only prevent that bore wear if it hasn't happened yet. If it's already leaking, it won't be able to apply full pressure to the TCC.
Reactions: santon
Spanky73
