Rear Wiper Washer Hose
Greg Christmas
11
USA
Hate to ask about what should be an easy part to find, but I can't find a replacement washer hose for my rear wiper. Any suggestions? Thanks!
If you have a u-pull yard nearby, should be plentiful and cheap.
fj4072
13
I had to extend my hose, kept popping off. I just went to the autoparts store and got some of the same size by the foot.
8,344
Might be less troublesome to either replace the entire Windshield Washer Arm...or get a New One via Amazon's Choices shown below and just Scavenge the Hose Portion off of it:
Greg Christmas
11
USA
Thanks, didn't realize the hose was part of the arm assembly, I'll get a new arm as the spring is a little weak and doesn't keep the blade against the glass near the top of the sweep. THANKS FOR ALL THE RELPIES!
Reactions: Redbeard and mrrsm
8,344
Forgot to mention this ...But Pulling the GM Compression Fit Windshield Wiper Arms is NOT a Trivial Matter. Before you go spending 1/2 of the Money on a Cheaper Non-Working Tool versus needing to get THIS Tool and wind up Inventing New Swear Words when that Arm refuses to budge... Consider getting THIS Thing instead... You will NOT regret it.
Make certain to apply some High Pressure Grease onto the Threads of the Tool and place or wrap a Soft Cloth around the Rear Wiper Arm to prevent the Heavy Tool from suddenly releasing and cracking the Tail Gate Window:
Reactions: Tankcruiser
8,344
THAT is Very Good Advice... First,.. Try to see if you possess @Mektek 's Luck and attempt its EZ Removal... and if not... At least you'll know where to put your HEBs (Hard Earned Bucks).
Sqrly
273
Livingston CA
I
It has always been trivial for me. I just remove the nut then patiently push and pull on the solid part of the arm and it slowly loosens up and slips off, usually in less than a minute.
gtp2nv
