Is there any tricks for doing the rear seals and bearings? 1 side has a small leak and they failed it for inspection. 600.00 plus to fix. Also told me that the water pump shaft is lose and needs to be replaced 687.00 to repair. Checked myself on price and from the dealer 193.00 for pump 46.00 for the 5 bolts that GM saids to replace when replaceing the pump. Is there any difference on the rear axle fluid say GM to Valvoline or are they the same but differ in price. Same specs with syn. And GL rateing. Any help wouldbe great thank you.
