Rear DVD No Power
Volphin
4
Hi everyone,
Working down my list on the 03 Trailblazer EXT...
The rear Audiovox DVD will not power up at all. Checked the fuse on the rear seat fuse block and tested good. Are there more fuses to check with this system? It has no power on the overhead console and the DVD under the center of the 2nd row will not eject or respond.
Thanks for your help!
V
Doesn't sound like OEM. You have to trace the wiring from the fuse block to your units to find the break. Unless the boxes are just dead now. What's the history?
There is one fuse specific to the overhead so that would be a start. I had the same problem and it was a non-stock DVD player even though it looked like it was. I had cut the supply wire when I yanked the non-functional remote starter from the previous owner. You might have to unscrew it from the headliner and trace the wiring. Mine was a hack job. It was tied in directly to the wiring in the steering column, no fuse.
Bbcman601
