First off I'm new to the site, I was on the other site but used it for nothing more than research. Today I changed the serpentine belt, thermostat, temp sensor, and coolant on my '03 EXT. When finished, I started it up and the rear A/C starts clicking. It goes away after a min or two and starts blowing air. Later I start it up again and it does the same thing; clicks then goes away. I did a search to see if this has been a topic before but found nothing that matched my symptoms. There was a thread where someone had posted that it needs to "calibrate" after the battery being disconnected and resetting the computer. Would this be what is going on here as well? Any insight provided would be greatly appreciated. Thank you in advance.
