- Aug 26, 2012
- 726
I've had a very slow leak on the rear diver's side tire. The leak wasn't really noticeable during the summer, but now that the temps are going down again, the problem is back. During temps below 60°F, I lose about 10 psi per day.
Last March, I took it to a local PepBoys (I know, mistake #1). The guy removed the tire and did whatever to look around for a leak, but found nothing. I didn't have an issue over the summer, so I forgot about it. Well, it's back again.
With the wheel still mounted, I sprayed the whole tire down with a spraybottle with water and some dishwashing soap and finally found where the leak is coming from. It's leaking very slowly on the inner bead, where the tire meets the rim. I guess it only leaks there when there's weight/load on the tire.
Question is:
Can a tire shop remove the tire and put some sort of sealant around the bead and re-install? Or will I have to start looking for a replacement?
The tires I have are Toyo Open Country A20's (245-65-17), and have about 75% tread remaining on all of them. I would hate to replace them if it's not really necessary.
Thanks in advance
Question is:
Thanks in advance
