Power Window Question
UMEXT
Registered Member
Dec 16, 2011
110
My express-down feature works on the passenger side, but not the driver side. However, the window does go smoothly up and down when one holds the button. Is this a switch issue, a motor issue, or some other part of whose existence I'm not currently aware?
Try swapping the Driver Door Module with the Passenger Door Module. If your express down feature returns, you have a bad switch in the module. You can try to repair it or get a used one off e-bay. If you get a used one, get one that matches your options. (heated seats/mirrors, memory seats, etc.)
De nada mi amigo :tiphat:
Hollywood1929
