- Oct 16, 2012
- 22
It's been brutally cold up here (Toronto) lately with the temp around -20 degrees C without the wind which is -4F for you guys to the south
When I start the vehicle in the morning the power steering pump makes a groaning sound for a few minutes before it warms up then all is fine.
Today the wife called from the mall parking lot to say she couldn't move the steering wheel. I drove it home and managed to man handle the steering wheel.
Upon closer inspection I found that the return hard pipe that is factory crimped to the rubber portion got blown off near the steering rack and emptied the reservoir contents. I also found the rubber hose
that connects to the cooler almost off - this is with a clamp installed!
I've never seen anything like this before. Could the return system actually end up in an overpressure condition?
I replaced the PS cooler this past summer and installed a new pump as well. Should I be looking at replacing the pump again?
I was also wondering if this could be caused by the Rack. I believe it's original and has about 215,000 Miles on it.
Any input would be appreciated.
Thanks.
![Wink :wink: :wink:](/forums/smilies/wink.gif)
Thanks.
