Hello Everyone... I am hoping some of you may be able to help me.. And yes I have done research and tried some suggestions.
Truck: 2006 Trailblazer LT w/ Auto Climate Controls
Issue: The other day after returning home and exiting the vehicle, the blower motor continued to run even without the key being in the ignition. I researched potential problems on Trailvoy and Google and it seemed the potential problem was the Blower Motor Control Module.
I went to O'Reilly Auto Parts and purchased the Blower Control Module (Part # BWD RU1321). This part matched a 2005 Trailblazer w/ Auto controls but they did not show anything for a 2006. After they did a little research, they said that this was compatible with my truck as well. They also referenced my old part that came off the vehicle. It looks just like the AC Delco part on ebay and around the internet. (It has the new 5 pin connector)
So this is the new 5 pin connector that requires me to cut off my old 3 pin connector and hard wire the new control module wires into it. No Problem.. So I perform the install and it worked right away with the key in the ignition on accessory, but when I started the truck, it stopped working. Then it came on again a few minutes later while driving, but stopped working when I turned off the truck and back on again. Figuring it was a fluke, I exchanged the part for another one and I still have the same problem.
I checked it with my Volt Meter and it shows power going to the module. It also shows power from the wire that goes to the blower motor and the voltage increases & decreases volts as I turn the speed up & down on my Auto HVAC control.
I guess Im just confused as to what the problem could be. Is the part I bought from O'Reilly just not as good as an AC DELCO or GM replacement part? I am expecting the blower to turn on almost immediately after I start my truck not minutes later or only work intermediately.
Any help, suggestions, ideas or anything else would be greatly appreciated, as I am trying to avoid going to the dealership for repair.
