Possesed Auto AC Unit
Vicompc
109
My HVAC is driving me mad, the fan speed will be low when it's over 90 outside with the interior registering over 100 degrees. Logically the fan should be on high, I can manually adjust the fan speed to high but the Auto AC seems to think it's cooler in the cabin than it really is. I can set a temperature with the auto AC button and it normally works for a minute or two, then the fan speed will drop down to medium or low (it seems to not like being on high :confused:). I have installed a new outside temp sensor, and a new blower motor resistor and blower motor. I have searched through the threads but i haven't seen any problems like this one. BTW the outside sensor is working correctly, and I can feel the air being pulled into the B-Pillar temperature sensor.
BRomanJr
371
Very strange behavior, There are also multiple sensors in the duct work under the dash. At this point it may require troubleshooting with a high end scan tool capable of reading all the sensors.
There is also a sun load sensor up on top of the dash, be sure you are not blocking it.
Try blowing some air into the B-pillar sensor to be sure the thermistor is not dirty (covered with dust).
It is acting like either the outside temp sensor or the B-pillar sensor is inaccurate.
You could reset the system and make it do a calibration by pulling the HVAC-B fuse for a minute. Put it back in, start the truck and leave it alone for a couple of minutes while it does its thing.
Docks
