2005 GMC Sierra 1500 WT with a 4.8 L engine 215 k.
My Blue Driver Scan tool reads PO466. It recommended replacing the canister vent valve. Easy enough and inexpensive, so I did.
Cleared the code but it returned. Watched several You Tube videos on the subject. I would replace the fuel pressure sensor next, but that's too much work without confirmation it has failed.
What do you recommend to buy (inexpensive) Scan tool to do the emission system diagnosis ?? I suspect it would be less than what the Auto Shop would charge.
- thanks, Kevin.
- thanks, Kevin.
