hey everybody, I registered several months ago and just always used the search function to solve most of my problems. But this one, I couldn't figure out the issue or find it in search.
Randomly i find my parking lights (the yellow front lights and the red tail lights) still on. First time it happened, i started pulling fuses for lights thinking that was the cause, that didn't work. Then I started pulling fuses and relays that dealt with the ignition, relays, or computer (example bcm and pcm). that didn't work either. Finally I just unhooked the battery and went to sleep. I plugged it back in and lights stayed off. The issue didn't happen for another few days and I thought it might have been the remote start (i have an Autostart remote start system). It stopped starting the car but it will unlock and lock the doors. I took them off my keychain and put them to the side. The issue started happening less frequently when I figured that out (once a month or 2 months instead of once a week or so).
It finally killed my battery so I got a new one, and got the installer to reprogram my Autostart (found who did the install, got the envoy used). it worked for one day, stopped again, i removed the fob from my keychain cause it left the lights on. No issues for 2 more months but then it happened 3 days in a row.
Things that could cause this or changed when this started.
1. Burnt passenger head light cable, cut and splice (butt connected)
2. Blower resistor replaced (same day)
3. Funky Autostart? The installer said this model is one of his oldest model and think I should upgrade. He said it is so old that it could be the cause of it as the module is going out.
Things I notice.
1. Not sure if it is the cold weather (living in Alaska) but sometimes when I start the car, it only goes to 11 to 12 volts and stays there for 5 to 15 seconds and then jumps to 14 volts and all the lights get brighter. If this happens, it is likely to happen, and making me think it is warning me of a bad alternator or battery (but I have a new battery)
2. A whining just happened 3 weeks ago, it gets louder with revs, water pump is new due to the last one failing on me (well my wife, she got stranded on the road, bitched me out cause it was making a weird noise, found out the fan was not balanced and caused a stress on the water pump shaft, and blew out the water pump), so I am leaning towards a bad alt, and this could be the cause of it?
Everything else works fine and I love my envoy (05 inline 6 SLE 4x4), but this is going to drive me crazy, and going to have the wife yelling at me if she is the one who gets stuck again.
Thanks
Things I notice.
Thanks
