P1120 & P1220 plus oil on camshaft sensor
mastercast
1
I got reduce power light and SEL on my 02TB 206K wonderful SUV
above codes
do you have to move the power steering reservoir to replace the camshaft sensor
nopaybob
97
To replace the cpas , yes
CaptainXL
above codes
Nope. Try to clean the sensor and make sure the bolt is secure. Sometimes the camshaft holddown bolt comes loose which could throw a light.
ziggyor
7
Just replaced my cam shaft sensor on my 02TB for a code and you DO NOT have to move the reservoir. For the 12 bucks I just put in a new one. Warning... the bolts are bot steel so applying a little too much torque I snapped the bolt. I also replaced the cam shaft solenoid because it was leaking oil. For that one you do have to move the PS reservoir but it's really easy just removing the 3 bolts through the pully holes.
Chris Moore
