- Apr 22, 2012
- 26
Hi everyone,
I know noises are hard to diagnose or explain over the 'net, but I'll do my best:
I've noticed a weird humming noise from about 35-60MPH (have not gone faster) coming from the drivers side front wheel area, as far as I can tell. It sounds very much like the noise you would get from a flat or low tire, or even similar to when you roll over light rumble strips, just not quite as loud or intense. It doesn't sound like a grinding noise of any kind. There are no vibrations. I recently had the tires rotated, but that didn't change the noise, same before and after. Both tie rods were recently replaced too. I starting noticing the noise around two or three months after they were replaced.
When I replaced the tie rods I didn't notice any movement in the wheel bearings. My guesses are it could still be a wheel bearing, or maybe something with the front differential? I replaced the front dif fluid a couple months ago, everything looked good. If I recall there were not any special additives or anything for the gear lube.
Any thoughts or things I should check?
Thanks!
Thanks!
