I noticed a new noise tonight, its a tapping or dull subtle thumping (best I can describe it) coming from the rear end when I go over bumps in the road.
I checked the end links for the rear sway bar when I got home and its not those. In fact, I replaced those end links a few months ago and they are still nice and tight when I grab hold of them and try to move them. The old ones were loose and made a racket, these new moogs seem great so far. I also replaced the rear swaybar bushings with polyurethane bushings from Prothane.
Once home I pushed down on the rear bumper repeatedly to try and replicate the sound. I was able to get the noise to come back - it seems to be coming from the passenger rear and is in sync with pushing down on the bumper. its as though two components are contacting each other as I push down and that's when you hear it....
The rear struts seem good though because there is no bounce when you push down and let go. The noise seems worse inside the truck when driving vs hearing it from the outside when I push down on the bumper.
I did have to push down quite firmly and use a bit of force to hear it. Maybe that's why it sounds worse when driving over bumps because the struts and springs are experiencing more compression forces than I can create with my arms?
I know this is tough to diagnose from reading a description on a computer screen, but has anyone come across this?
What other components in the rear suspension tend to make those noises?
Thanks
Thanks
